what iridium plugs for edelbrock LT1 heads?
Old 03-29-2017, 09:37 AM
glfrmrk's Avatar
Hi all, I haven't been on the forum in a while. I have a "93 Z28 with a LT1 with Edelbrock LT1 heads. I have been using Champion RC12YC plugs and now they are in need of a change and I want to go to an iridium plug. My question is, do I just find a 14mm x .750 gasket seat iridium plug and go with the gap as they come out of the box or try to find a plug that is pre gapped at .050" (Chevrolet reccommended gap)? NGK 6341 fits except the gap is closer to .030". any help would be appreciated. What should I expect with a smaller gap? The engine has 10.4:1 compression, cam that is the closest to stock that Comp offers, Edelbrock LT1 heads and intake, Holley 52mm throttle body. Thanks in advance.
glfrmrk is offline
Old 03-29-2017, 12:17 PM
Re: what iridium plugs for edelbrock LT1 heads?
See this chart.....
https://www.camaroz28.com/forums/n2o...-chart-431689/
LT1 w/ Trick Flow & Edelbrock Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Hopefully, you had those heads ported, because out of the box, they are not much of an improvement over the stock heads. Edelbrock claims 24 HP increase.
Injuneer is offline
