What?!!? I have Cruise Control? Why won’t it work?
Old Mar 22, 2004 | 05:59 PM
stars1010's Avatar
So I bought my car over 3 years ago and I realized I had the buttons for cruise control but the labels for them were rubbed off. I messed with the buttons a few times but they never did anything. So yesterday I finally decided to look up the RPO code for cruise. It’s K34; so I go out, look in the glove box and I’ll be damned I do have the option. So I pull out my Camaro repair book and find that the control module for cruise control is on the driver side frame rail at the front of the car. I jack up the car pull off the plastic cover and there it is. So why wont it work? Anyone have some tips?
Old Mar 22, 2004 | 06:15 PM
stars1010's Avatar
All the cables and electronics appear to be hooked up.
The cable on the throttle body/linkage is hooked up and the other end is hooked into the control module.
The wires are hooked into the control module.
The speed sensor is hooked up.
I hear if the third brake light works then the fuse is ok.
Hmmmm what to do, I'd like to get this to work; ya know how many long distance trips I’ve taken over the past few years? I sure could have used this.
Old Mar 22, 2004 | 06:34 PM
KeVMaN's Avatar
well... u know how to do it right? move the switch to the middle, take your foot totally off the gas and tap the button on the side quickly. I thought mine was broken for the longest time until I got the hang of turning it on. I duno maybe yours is actually messed up lol.
Old Mar 22, 2004 | 06:42 PM
flowfx's Avatar
haha, I didn't think I had cruise control either until one day a few months ago (after 2 years) I was looking at the "sticks" and saw "trol"
I was like a giddy little school girl!
It also explained why while driving 30+ my car would randomly STAY at that speed and It would FEEL like CC was on.. Automatic CC or something? It's scared the crap out of me a few times, usually when I'm doing 45 and just let go of the gas to roll to slow down
Old Mar 22, 2004 | 07:09 PM
Re: What?!!? I have Cruise Control? Why won’t it work?
If you have a repair manual, all you need to do is follow the troubleshooting instructions. It's usually quite involved.
Old Mar 22, 2004 | 07:16 PM
stars1010's Avatar
Ok I’m dumb founded…..Everything seems to be hooked up? My repair manual only shows how to check it being hook up doesn’t go into detail about repairs. I went and test drove it doing exactly what my owner’s manual said and it didn’t come on.
What should I do?
Old Mar 22, 2004 | 07:28 PM
stars1010's Avatar
Anyone else have something similar happen? Do I need to replace the control module?
Old Mar 22, 2004 | 08:53 PM
GreenbeanZ28's Avatar
heh, my cruise stopped working when I swapped over to an OBD1 computer. I just yanked the crap out then. Less weight, go faster.
Old Mar 22, 2004 | 11:43 PM
Bud M's Avatar
If you have a burned out bulb in your 3rd brake light it can stop the CC from working.
Old Mar 23, 2004 | 04:20 AM
Zerosheaven's Avatar
mine works when it wants to work, i got quite involved and tested all the wires and their correct voltages and everything, the complete system looks 100 percent healthy so i have no clue why it doesnt work all the time...im thinking it has something to do with the fact that i removed CAGS
Old Mar 23, 2004 | 10:44 AM
White Knight 95's Avatar
Mine worked more reliably after I removed CAGS, but it still only works when it wants to. I replaced the control module, and that didn't help either. What a beautiful waste of a few hundred bucks.
Old Mar 23, 2004 | 11:34 AM
t-trimz28's Avatar
Mine wasn't working when I purchased the car. I replaced the burned bulbs in the third brake light and it works perfectly now.
Old Mar 23, 2004 | 12:42 PM
speed76demon's Avatar
My cruise control only works every once in awhile also. More times than not it works but sometimes it just stops working
Old Mar 23, 2004 | 12:47 PM
blackbirdta's Avatar
mine doesnt work either...i found out after i bought the car, but at the time all lights worked...i havent gotten around to figuring it out yet
DirtyDaveW
Dec 1, 2016 05:37 PM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
squarehead
Jan 15, 2015 07:02 PM
jayblev95
Jan 6, 2015 11:52 AM
Collector Car
Jan 5, 2015 10:58 AM
