What is the hose from water pump
Old Jan 29, 2009 | 10:20 PM
Danny McAdams's Avatar
I broke the plastic elbow that is in the hose from waterpump to heater at from of eng. it broke at the elbow all I saw in it was a coil spring. I cut the one off my other eng with enough hose to couple it, for some reason my heater will only get barely warm, got 180 stat and temp guage stays just under 180 should put out hot air. I checked the diverter door it's ok. any ideas.
Old Jan 30, 2009 | 06:45 AM
There is a flow controller in the heater inlet hose. It is a couple of inches long and has a spring in it. I assume it needs to be installed in the right direction to work properly. Otherwise, you might need to flush your heater core.
Old Jan 30, 2009 | 10:09 AM
I installed the flow control exactly as it was on other eng, since i saw no check valve or ball thought it may have lost out of it, I only saw the spring. oh well... I'll flush the heater core. Thanks D Mc
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
