What hose is this?(Radiator to Waterpump)
Old Jun 25, 2003 | 02:22 PM
95BlackTA's Avatar
On my 95 TA..its the hose that goes from the bottom of the radiator(if you're sitting in the driver seat, its bottom left)..and it goes down like 2 inches, and then goes up to the waterpump. It is leaking from both parts where it connects with clamps, so i need to get a new one and hopefully that will stop the leaks.
If noone here knows, I guess can discount look the part number up? Maybe someone here has an extra one?
Old Jun 25, 2003 | 02:30 PM
It's the bypass hose. Cars that don't have oil coolers have this hose to "bypass" the oil cooler.
GM PART # 10197675
Old Jun 25, 2003 | 03:30 PM
95BlackTA's Avatar
Ya i guess its number 16 on that page?
this guy on here called it the lower radiator hose..
http://www.ls1.com/forums/showthread...hreadid=333234
Old Jun 25, 2003 | 04:30 PM
#16 is the one.
Old Jun 25, 2003 | 06:28 PM
Mtrhds94Z's Avatar
It's 5/8" ID on one end x 3/4" ID on the other end [in case you need to rig up something] engine bypass hose: goes from 'lower drivers side radiator inlet' to the 'lower water pump drivers side outlet' ..
GM lists it as 'water pump outlet hose' [frequently called 'engine bypass hose'] GM 95-7 p/n 10197675 $12.10 GM list[same p/n for 93-4]
I have never really heard of it called the 'lower radiator hose' just make sure it's teh above diameters and NOT 1 1/4"ID [rad inlet hose] or 1 3/16" ID [rad outlet hose], or it isn't the right one..
Old Jun 25, 2003 | 10:28 PM
95BlackTA's Avatar
Ok...hmm well i called discount, and gave them the Gm part number, and he said he had no matches??? So i told him what it was, and he said its the lower radiator hose..so he ordered it, should be hgere tomorrow..guess ill be able to look at it and see if it is the right one or not.
Old Jun 26, 2003 | 06:23 AM
Mtrhds94Z's Avatar
I have a pic of that hose off the car if you need it.. [I have to email it tho]
Old Jun 24, 2010 | 09:16 PM
BUSCHZ28's Avatar
I have a leak in mine as well 95 z28 but im also overheating im thinking its the thermostate because no leaks coming for the water pump.......... any suggestions!!!!!!!!!!! Also i have a ticking noise coming from the engine, how could i resolve this i recently had an oil change and used a synthetic blend thinking it would help and it did not!!!!!!
Old Jun 24, 2010 | 09:27 PM
You will usually get the best results if you post your own new topic.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
