What the heck is this thing??
I was under my car the other day changing a motor mount and I saw this long black tube sticking down from the air intake tube..... It's just a hollow tube, it rounds off at the end. I have a 95 z28, what the hell is it? what does it do?
You unfortunately can't just "cut it off" as you will then have a large opening in your intake allowing tainted air to get into your engine = bad.
Some people have done the ghetto rig for it, which is make some sort of fitting that will cover the hole and keeping it there securely.
Or, for approx $40, you can get a 1LE intake elbow, which is the GM intake elbow without the silencer.
Bottom of a shampoo bottle works great. I put it in then siliconed it in place to make sure it wasnt going anywhere. Worked for well over a year until i ended up tearing the elbow in a unrealated situation.
From: Council Bluffs, IA Might as well be Omaha though!!!
It's your cars *******!
I made a perfect plug with a 2x4 and shaped it with a belt sander, fits perfect I even contoured it a little on the inside part to keep it from sticking up too much in the airstream.
cmsmith
Mar 16, 2015 02:34 PM
Hal Fisher
Sep 14, 2002 09:36 PM
