What Headers used with Lowering springs
Old Mar 9, 2003 | 10:38 AM
NHSZ28's Avatar
Can you use long tubes with 1 inch lowering springs? what is everone using with there lowered fbody???? also jet hot offers emmission hook up long tubes would that be better to get than non emmissions???? main factor is when i lower my z if i will have ground clearance issues with long tubes???? pictures?
Old Mar 9, 2003 | 11:15 AM
brandboZ28's Avatar
Yes, you will have problems with clearance. I have the MAC headers and I scrape everything. LT's are worse. Im not saying lower your car or dont get headers, I would suggest both actually. You just have to be careful about where you go and stay away from speed bumps. Thats what I do. Good luck.
Bo
Old Mar 9, 2003 | 11:32 AM
chesee48's Avatar
Especially if the 1in springs lower your car more then the advertised amount, you'll run into some major problems. My old sportlines lowered the car way more then they advertise. So unless its EXACTLY 1in drop, then i'd advise to think about something else. Maybe some coil-overs that u can adjust till where u wont scrap or something like that.
Noenav
Mar 1, 2019 07:38 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
PaulN64
Aug 8, 2002 05:39 AM
