what header gasket to get, and where??
Old Jul 7, 2003 | 09:01 PM
TMDZ28's Avatar
as the title says, i got a header leak, it turned out my gasket is bad. darn stock gaskets, i guess edelbrock did not include a good gasket. anyone knows which one is the best to get, and where, also the part number...thanks guys
Old Jul 7, 2003 | 09:26 PM
Camaro_Maniac63's Avatar
I used UltraSeal gaskets from Autozone while installing my headers, and I am very happy with them, no problems so far. ( Watch my gaskets burn tomorrow, me and my big mouth. ) Good luck man.
Old Jul 7, 2003 | 10:07 PM
blown383's Avatar
Felpro 1406 are the best.
-B
Old Jul 7, 2003 | 10:11 PM
TMDZ28's Avatar
-B
the guy over in superior automotive (anaheim, CA) told me that. does summit sell them?? if so, what's the part number, thanks a lot. what would i do without you guys (i wont have to buy these headers)
Old Jul 7, 2003 | 10:15 PM
gb95zconv's Avatar
I got my felpros from Thunderpreformance.com. I got 2 sets because the shippn was the same as for 1 set and I know Ill need them down the road sometime.
Old Jul 7, 2003 | 10:17 PM
kirschman's Avatar
Get the factory metal manifold gaskets. They're a 2 piece type metal gasket. I used em on my Mac's twice and had no leaks whatsoever.
Old Jul 8, 2003 | 11:41 AM
EviLBoX's Avatar
I've been using the same Felpro gaskets for nearly 2 years now without any problems, they definitely get my recommendation. The part number is 1406, they are the "D" port gaskets.
Old Jul 8, 2003 | 12:17 PM
94Zpower's Avatar
I am using the stockers and I do have leak that driving me nuts!!
Old Jul 8, 2003 | 12:42 PM
Prorac1's Avatar
what he means is factory metal gaskets. I used em and theyre great. If a bolt loostens up and you get a leak, you simply tighten the bolt and the leak goes away. Theyre almost blow proof.
Old Jul 8, 2003 | 12:47 PM
94Zpower's Avatar
I have stage 8's so i doubt that the bolt loosend up.
is it possible that the header is warped?
Old Jul 8, 2003 | 12:51 PM
snorkelface's Avatar
I noticed in an article in a recent "Camaro Performers" that they used some soft aluminum gaskets from Flow Tech (part #99150AFLT). Does anyome have any experience with these?
Old Jul 9, 2003 | 09:25 AM
gb95zconv's Avatar
I tried them and they still leaked alittle.....plus I had to drill some more holes in them because the didnt match up with the headers and that was a PITA.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
