what happens when your 02 goes bad
Old Oct 4, 2007 | 03:21 PM
ROUDA's Avatar
I put lts on my camaro and I knew for a while that the 02s would need replaced I am trying to get the car to pass inspection with no cat but thats not easy so it didnt pass when I was driven it home it started bogging out real bad losen all power wouldnt real rev up unless I pushed the peddel to the floor almost could bad o2s cause this.
Old Oct 4, 2007 | 05:03 PM
The O2 sensors help control the A/F ratio. When the sensors are bad, when the wiring goes bad, when you have exhaust leaks before the O2 sensors, or if you have excessive misfires, the A/F ratio goes off spec, the engine may run poorly and the emissions may be excessive.
But "bogging out real bad" could be related to the O2 sensors, the ignition system or the fuel system.
Old Oct 4, 2007 | 10:43 PM
JP95ZM6's Avatar
When my (Bosch) O2s failed, the car ran real lean; it was pulling a lot of fuel as indicated by near 108 BLMs, and needed extra throttle to accelerate. Car was 'jerky' at low throttle, and would surge during light throttle cruise. Cam surge was real bad then, too. Monitoring the 02 voltage showed the signal was not swinging high/low saveral times a second like it was supposed to. It still moved, but slower than the 10/second or so that's normal.
When you get new sensors, I recommend Delphi's. (not Delco, Delphi's will be like OEM but Delco can be a rebrand, according to NAPA.)
Old Oct 4, 2007 | 11:55 PM
Irish350's Avatar
one of my o2s was bad and it was causing my motor to run really lean, which caused knock, which caused more lean ness
Old Oct 5, 2007 | 08:02 AM
ROUDA's Avatar
ok thanks I guess I will put new o2s on and see what happens.
Old Oct 5, 2007 | 12:45 PM
moroso99's Avatar
that should help, mine went and the left bank completly stopped. car studdered and missed like crazy. i changed the o2's, reset computer, everything fine.
Old Oct 5, 2007 | 11:34 PM
Trannykiller's Avatar
loss of power and red hot manifolds
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
