What is a good ign. on power source?
Old Aug 13, 2003 | 03:23 PM
Dave Feerst's Avatar
I'm wiring up a switch panel and I want all of my switches to work on ign on. I'm running a 10 Ga. power wire to a distrobution block and then Ill route it to the individual switches / relays with smaller wires, I just need a good power souce, I know I could use the cigarette lighter but I want somthing that will take a bigger draw. There should be an igniton relay somwhere that would work better. anyone have any ideas?
Old Aug 13, 2003 | 05:49 PM
anyone?
Old Aug 13, 2003 | 05:53 PM
Cmr0z28's Avatar
i thought the cigarette lighter would work for my cutout switch, but i was wrong.....its on all the time. i used the radio fuse
Old Aug 13, 2003 | 05:54 PM
FastZinTennessee's Avatar
Look under the dash at the wires coming from the ignition switch. They are about 10 gauge.
Orange-accessory power, has power when the key is on, goes to zero while cranking, then power comes back after cranking
Pink- ignition, has power when the key is on, even when cranking.
John
Edit- these wires run in a big bundle, coming from the steering column and there is a plug to the left of the steering shaft that is easy to get to if you drop the underdash pieces.
Old Aug 13, 2003 | 06:24 PM
ok, so the pink is the one i want, thanks!
Old Aug 13, 2003 | 06:31 PM
No problem!
Old Aug 14, 2003 | 01:31 PM
There's a tap in the fuse block at the end of the dash, protected by the fuse right above it. It is a spade lug, labeled "IGN" and turns on and off with the ignition. I use it for my AutoMeter instrument lights, tach, N2O relay signal power source, etc.
Crimp a spade terminal on your wire, and plug it in where the orange wire is. . That's on a 94... may be slightly different on later years. There is also an unswitched power source on the fuse panel.
Why cut into the under dash wires, when there is a source already available????
Old Aug 14, 2003 | 02:47 PM
Even better, thanks!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
