What is a good code scanners for the lt1?
Old Apr 14, 2006 | 01:11 AM
yzblue125's Avatar
I know there is a millon of these things out there but whats the best for the money right know, what about those 40 dollar ones at Advanced? thanks guys
Old Apr 14, 2006 | 03:33 AM
Evil Eric's Avatar
Re: What is a good code scanners for the lt1?
actron has some great stuff for obdII cars.
Old Apr 14, 2006 | 11:29 AM
The $40 scanners may be the "short-the-pins" scanners for OBD-I. You need to make sure its an OBD-II scanner. The cheapest OBD-II (codes only) scanner that I am aware of is one from Harbor Freight for somewhere around $40. Brent Franker tried one and it worked fine.
http://www.harborfreight.com/cpi/cta...emnumber=46030
Old Apr 14, 2006 | 11:33 AM
moparman's Avatar
What Fred said.
Plus, in addition to Actron, AutoXray is another provider of code readers and scan tools.
Old Apr 14, 2006 | 03:42 PM
94YellowTAGT's Avatar
Just buy an 80 dollar cable and download freescan.
Old Apr 14, 2006 | 04:24 PM
Does Andy have an OBD-II version of Freescan? Last I checked:
Please Note: FreeScan is not OBD-II compliant. It will only work on the vehicles listed below.
FreeScan currently supports (from version 2.0):
GM 1992-93 Camaro
5.7L MFI LT1 1992 IY CAR
5.7L MFI LT1 1993 IY 1,2F
GM 1994 Camaro - Impala SS - Corvette
5.7L SFI LT1 1994 1,2F
5.7L SFI LT1 1995 1,2F
Please Note: FreeScan is not OBD-II compliant. It will only work on the vehicles listed above.
Old Apr 14, 2006 | 04:46 PM
Sorry,
I just tend to pay attention to ODBI stuff. What about Datamasters free trial.
Old Apr 15, 2006 | 08:35 AM
Originally Posted by 94YellowTAGT
Sorry,
TTS DataMaster is OBD-I only.
Old Apr 15, 2006 | 02:05 PM
JimboManJones's Avatar
don't wanna hijack but whats a good scanner that'll tell you everything, like voltages at certain sensors, actual rpms, actual water temp and oil pressure, and all that great stuff?
Also where can I pick up one of these bad boys?
Old Apr 15, 2006 | 04:37 PM
AutoTap will read hundreds of parameters...... its a software package you run on your laptop. You can configure a "dashboard" on the screen and display whatever you want real time, and log numerous sensors and engine parameters for an extended period of time. The "enhanced parameters" option is what you want.
There are many other software scanners available with similar features.
Unfortunately, the PCM does not have input for the oil pressure.
Home Page:
http://www.autotap.com/
GM Enhanced Parameters (your car does not support all of these items):
http://www.autotap.com/enhanced_parameters_gm.asp
Old Apr 16, 2006 | 10:28 PM
would programs like LT1 edit or hp tuners also allow you to check all those things?
Old Apr 16, 2006 | 11:59 PM
For LT1_Edit, it depends on the year of the car. The OBD-I version of LT1_Edit is available with a copy of pcmcomm scan software. But the OBD-II version of LT1_Edit does not have a scan program included.
HP Tuners has a scan module available with their VCM Suite Pro package. I was under the impression that HP Tuners was for Gen III (LSx) series engines.
Old Apr 17, 2006 | 05:56 PM
I don't know if hp tuners is made for an lt1, my friend told me to get it, so I figured it was, who knows though, hes got an ls1
Old Apr 17, 2006 | 08:52 PM
cg4743's Avatar
I just did an OBDI conversion, where can I get a cable for my laptop and what's the best program to use. I've realized that I now need to be doing some monitoring and learning to program? Any books out there that would help get me started learning?
Old Apr 18, 2006 | 06:09 PM
EviLBoX's Avatar
Instead of Autotap I'd look into http://www.obd-2.com I've been using this for years and it does everything Autotap does, but for a lot less.
