What gear do I have
Old Feb 8, 2003 | 06:20 PM
dog house's Avatar
What gear do I have
I have a 96 z, and i was wondering how to figure out what rear end gear my car has.I am going to change one of the axl seals soon, so i will have the cover off.I know that you can count teeth, but what then.How do you figure it out from that.
Old Feb 8, 2003 | 07:47 PM
94B&RZ-28's Avatar
If you have an M6 you have 3.42, A4 you have either 3.73 or 3.23
Old Feb 8, 2003 | 08:30 PM
MRZ28HO's Avatar
I think you meant to post 2.73, not 3.73.
Old Feb 8, 2003 | 08:57 PM
dog house's Avatar
My car is an A4, so now how can I tell exactly what gear I have.
Old Feb 8, 2003 | 11:09 PM
Capn Pete's Avatar
Check the codes on the door sticker (on the edge of the driver's door). There should be a code GU2 or GU5 if your car is an automatic.
GU2 = 2.73's (more likely to have)
GU5 = 3.23's (optional gear)
GU6 = 3.42's (6-speed gear)
Also, when you have the cover off, if you counted the teeth on the pinion and ring gear, you should get 15 and 41 respectively (sorry I don't know the combination for 3.23's..........although I know it's 12 and 41 for 3.42 gears).
Anyway, HTH
Old Feb 9, 2003 | 02:54 AM
stik6shift98's Avatar
Anyway, HTH
the thing with the vin is smart
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
