what gaskets to use with rk sport/as&m headers?
just ordered my rksport middies off their site for 450+s&h
i think they come with gaskets but are they good enough?
should i just buy some felpro gaskets or use the ones they give me?
Originally posted by SuperDavez28
No i wouldnt use them. Definately get some new felpro header gaskets. Im also getting some 2.5" collector gaskets (felpro).
i think i will go with them
i was thinking about it more and i just don't want to take the chance with whatever they give me
thanks
fel-pro #1406 and the collectors are #2014 -2.5" and #2001 for 3". I think you'll need 1, 3 inch collector gasket for the cat. Im looking at summit and CMS. Total will be around 30 bucks. Think this is right hopefully someone will correct me if im wrong, this is what ill be getting, but what i get is usually wrong so u dont gotta listen to me
You know that piece in the driver side header. Are you supposed to take that off to fit the header in? Im still confused about this, mine came assembled but looks like u gotta cut some metal to get it off then put it back on when the header is in?? i mean they are 3 piece headers but they come assembled in 2 pieces. Does'nt make any sense to me
You can get all the gaskets at Advance or Autozone if you want to skip the shipping/waiting with mail order.
1406's, 2.5" collector gaskets, and 3" for the y to the cat. SuperDave preaches the truth
I use 1406's, and Mr Gasket Ultra's for everything else. They're cheap, plentiful locally, and do a great job!
I have RK's, by the way.
You may want to look into having the slip fit part of of the y-pipe welded up after you get it where you want it. You'll see what I'm talking about when you assemble them. I'm not talking about the primary, but the part where the individual collector y pipes merge into. That little bolt clamp set up the have doesn't work very well. It cost me $10 to get them cut off and weld the y.
SuperDave, yes, I took a hack saw to that part of the flange on the drivers side yeader, just cut that off. It helps to have it separated for install/removal/leak prevention.
I use 1406's, and Mr Gasket Ultra's for everything else. They're cheap, plentiful locally, and do a great job!I have RK's, by the way.
thanks for the replies guys
i might go out and buy the gaskets tomorrow
one more question...
you guys running stock spark plug wire location?
i was searching through a few posts and it basically said you don't need it and i'm trying to save whereever i can so...
what do you guys think?
Originally posted by jkipp84
Mine are in the stock location. Some zip ties and attention to detail and you should have no problems. I've never burned a wire.
did you put some heat sleeves on any? maybe the pass. side?
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
