what gaskets to use for porting?
Old Nov 12, 2003 | 02:01 PM
1badasZ's Avatar
Question what gaskets to use for porting?
what gaskets are you guys using to port your heads to? are there any that are bigger than stock?
Old Nov 12, 2003 | 04:29 PM
FastZinTennessee's Avatar
I went over to the Chevy dealer and got a pair of GM gaskets. Surprisingly the ports on the gasket were close to the size of the ports on the intake manifold. There is a lot of material to take off the ports on the heads though
Old Nov 12, 2003 | 10:37 PM
Ai's Avatar
Ai
I'd use the one you're going to run.. size isnt much of an issue, it'll likely be large enough to flow 80+cfm more than your heads ever will
Old Nov 12, 2003 | 10:47 PM
S.J.S.'s Avatar
I assume your talking about match porting. I used the Fel-Pro gaskets. They showed a lot to be removed.
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
Noct
Jul 14, 2015 01:18 AM
pimpen1024
Jul 8, 2015 09:08 PM
4586
Apr 29, 2015 01:43 PM
