what gaskets req. for opti change?
Old Dec 18, 2005 | 08:30 PM
droptop z's Avatar
I'm going to be changing out my opti and was just wondering what gaskets I will need, I am going to get a new water pump gasket but was just wondering if there is any other ones I'll need.
Old Dec 18, 2005 | 10:07 PM
Blackthunder50's Avatar
Re: what gaskets req. for opti change?
For the water pump there are two gaskets for the two sides. If I remember correctly there are two O-rings that slide over the opti shaft. Thats what I remeber when I did the swap for a new one. Have fun!
Old Dec 18, 2005 | 11:08 PM
Lt1t56's Avatar
I would recommend replacing the opti seal while you are there and possibly the water pump drive seal also. You can get a timing cover gasket kit from Fel-pro for $15.00. The opti seal is easy, do a search on the water pump drive seal if it is not installed properly you will have a big oil leak.
Old Dec 19, 2005 | 09:47 AM
Bud M's Avatar
Combine the previous 2 posts and you've got them all. 2 wp gaskets, 2 o-rings for the wp ds, 2 timing cover seals. Don't rip the seal pushing it over the wp ds. I use the cone shaped cap from a bottle of gear lube placed onto the wp ds to protect the seal.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Sergio
Jan 27, 2016 04:27 PM
PCLZ28
Dec 24, 2015 05:19 PM
thenewkid
Nov 27, 2014 09:41 AM
