What is the function of this part??
Old Feb 26, 2004 | 07:06 PM
PatriotTA's Avatar
OK, it appears to be some kind of brace and is located above the panhard bar. It bolts up to the car on the driver side, and to the same bracket as the panhard bar on the passenger side. Will I have problems if I remove this? I need to remove it for clearance for dual exhaust.
Old Feb 26, 2004 | 07:50 PM
Dave89IROC's Avatar
that sounds like the panhard bar bracket brace, if you remove it, it is likely that the panhard bracket will flex and/or rip off the car
Old Feb 26, 2004 | 08:06 PM
RedHottG2's Avatar
Not sure about this, but could it be the tunnel brace ? It is used to strengthen the floorplan and reinforce the driveshaft tunnel ? If so I wouldnt remove that.
Old Feb 26, 2004 | 09:34 PM
OldSStroker's Avatar
Listen to Dave.
DirtyDaveW
Dec 1, 2016 05:37 PM
novaiiman
May 15, 2016 11:36 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
