what fuel filter do you guys recommend?
Old Jan 28, 2004 | 05:48 PM
cz28s's Avatar
what fuel filter do you guys recommend and how do you put it in and any tips or tricks are helpful as well. thanks Cory
Old Jan 28, 2004 | 06:40 PM
cz28s's Avatar
ttt
Old Jan 28, 2004 | 06:45 PM
QCKZ28's Avatar
i bought mine from walmart for about $10.
jesse
Old Jan 28, 2004 | 07:06 PM
FacelessZ's Avatar
a fuel filter is a fuel filter...doesn't really matter which one you go with...
Old Jan 28, 2004 | 07:36 PM
Terran2k's Avatar
i used a puralator one, cheap, works well so far, well as far as i can tell.file:///usr/share/doc/HTML/index.html
Old Jan 28, 2004 | 07:46 PM
anasazi's Avatar
three tips (i learned the hard way)
1) DO NOT EVEN ATTEMPT WHILE CAR IS HOT... yea, this has bad idea all over it
2) don't do it on a full tank. the less gas in the tank the better
3) attempt to bleed the pressure off using the valve on the back of the fuel rail. if you don't wanna do this, you can just let it sit overnight and it'll bleed itself off.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
