What exactly is the air injection system
Old Oct 25, 2006 | 03:52 PM
SPEEDYGUN's Avatar
I have seen mention of it, but I have no idea what the AIR system really is?
Old Oct 25, 2006 | 05:23 PM
At engine startup, the AIR pump (electrically driven) turns on and blows fresh air into the exhaust manifolds. This air combines in the exhaust system with the unburned fuel from the rich "cold start" A/F mixture, and the heat that is released helps the catalytic converters heat up faster. They won't work until they reach ~600*F. Once the cats heat up, the AIR pump turns off and is not used until the next engine start.
Old Oct 25, 2006 | 06:02 PM
SPEEDYGUN's Avatar
Where is the air pump located and how hard is it to change? Price?
Old Oct 25, 2006 | 06:11 PM
ryan woods's Avatar
Why Would You Want To Change It Just Take It Off!
Old Oct 25, 2006 | 06:33 PM
TobyZ28's Avatar
Its located for most cars on the drivers side of the motor just to the side of the waterpump/opti. Very easy to remove The tubing is a bit of a pain. I managed to remove all the tubing for the air system (on 2 cars) without cutting although a lot of people just opt to cut the tube.
On the earlier years it was in a slightly different spot but still on the driver side.
Be sure to have M22 drain plug to plug your manifolds with once you remove all the tubing.
Old Oct 25, 2006 | 08:57 PM
SPEEDYGUN's Avatar
Taking it off would result in the SES light coming on wouldn't it? That would lead to Inspection problems for me
Old Oct 25, 2006 | 09:15 PM
LT1 POWR's Avatar
You can have it tuned out with a dyno tune or a mail order tune. Is there something wrong with yours, or why do you want to put a new one in?
Old Oct 25, 2006 | 09:36 PM
It depends on the year of your car, and you didn't bother to give us any info. For example, 93-95 will not set an SES light, as long as there is a good fuse in the system. And the M22 plugs are only applicable for certain years. And there is an AIR pump recall on some years - dealer fixes it for free.
Without adding basic info about your car - year, model, engine, tranny and any major mods - you're making it more difficult for people to accurately answer your questions. Why not add a "signature"?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sauced
Mar 29, 2015 10:53 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
