what else is needed for a cc305??
Old Aug 1, 2003 | 05:52 PM
SSnakeEater's Avatar
I want to get a CC305 and i am pretty sure i need more than just the cam to install....
if i need to get them, specificly what lifters and valve springs do i need to get and what else do i need?
Old Aug 2, 2003 | 12:18 AM
slashz28's Avatar
stock replacement lifters (gm, speedpro, etc.) theyre all the same. you could just keep the ones you have if you want though. theres also the comp r lifters, which are pricier , but i dont see why youd really "need" those. youll definitely need better valvesprings, the "double " type (sorry, dont know specifics about em ). a set of roller rockers would be beneficial as well. and a pcm tune, for sure. if you think you need to upgrade your injectors (which i dont think you do), you could do that too. could also get a new timing chain, stock replacement, lt4, lt4 hd, double roller, all depends. (if you do get a new chain, make sure to replace the sprockets as well). youll also need gaskets (timing cover, intake manifold, etc.) just a few ideas hth
Old Aug 3, 2003 | 05:42 PM
so what your saying is all i really need are new valve springs???
where would i get these? how woul di know which ones to get specificly?
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
