What are EGR bolt sizes? Must have ASAP
Old Jul 9, 2003 | 03:20 PM
ChickenScreamer94's Avatar
i basically need to know what size the bolts are that hold the valve on. PLease help me. any tips on removal also?
Old Jul 9, 2003 | 03:22 PM
Wrench/socket size is 1/2" or do you mean thread and pitch?
Old Jul 9, 2003 | 03:25 PM
i tried a half inch and it is too big? btw in what direction do you rotate the nut to make it loose, like if you standing in front of the car is to the right to loosen since it is on the back?
Old Jul 9, 2003 | 03:58 PM
Sounds like you are trying to take the nuts off the studs. There are no "bolts" for the EGR valve, only studs. I think you are asking for the wrench size. They are conventional threads.... from the front of the car, with the wrench on the nut, you need to rotate the wrench clockwise to loosen it. Somebody else will have to tell you the metric nut size.
Old Jul 9, 2003 | 04:00 PM
got_hp?'s Avatar
i just took mine off this morning............i cant remember for sure, but i think it was 10mm
gm engineers can all burn in hell, engines should not be this uncomfortable to work on.
Old Jul 9, 2003 | 04:12 PM
Don't know what to tell you. Mine are 1/2".
Old Jul 9, 2003 | 09:33 PM
Mr. shoebox, you are right. It is a half inch. I just was using a funky "quick turning" wrench that is just plain retarted. Thank you so much for the help. I got the job done about 3 hours ago
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
ChrisFrez
Jan 11, 2015 03:47 PM
thenewkid
Nov 18, 2014 12:57 PM
