What is the duration when using 1.6 RR's on the XE 224/230 and 230/236?
Old Apr 22, 2003 | 06:10 PM
ucrazymonkey's Avatar
When running 1.5 rockers the 224/230 cam is .502/.510 on a 112 LSA and the 230/236 is a .510/.520 on a 112 LSA. What would it be when using 1.6 RR's.
Which cam will keep me from having to rev over 6000 RPM while making power?
Old Apr 22, 2003 | 06:14 PM
Bryan Smith's Avatar
NCC-224XL
XTREME
Comp Cams 224XL Camshaft 224/230 duration @ .050", .503"/.510" lift with 1.5 rockers, .536"/.544" lift with 1.6 rockers.
NCC-230XH
XTREME
Comp Cams 230XH Camshaft 230/236 duration @ .050", .584"/.585" lift with 1.5 rockers, .622"/.624" lift with 1.6 rockers.
Old Apr 22, 2003 | 06:20 PM
Z95m6's Avatar
the duration isn't changed by the 1.6's
Old Apr 22, 2003 | 06:25 PM
Mindgame's Avatar
~6000 rpm?
Go with the 224 or something even a tad milder like 218.
Of course you made no mention of the engine size?????
-Mindgame
Old Apr 22, 2003 | 06:29 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
it has no effect on the total durraction, but does increase durration at .050 which is usually what you compare
Old Apr 22, 2003 | 06:54 PM
Im sorry, what I meant was the lift.
.622/.624 lift on a 230/236 XE cam when using 1.6RR's
Need lift numbers when using 1.6RR's on the XE 224/230 and the 230/236 cams.
Old Apr 22, 2003 | 07:04 PM
IROCZZ3's Avatar
Pretty simple...divide advertised lift by 1.5, then multiply that by 1.6.
XE 224/230= .535/.544 with 1.6 rockers
XE 230/236= .544/.554 with 1.6 rockers
Old Apr 22, 2003 | 07:56 PM
Redstar's Avatar
i dont think it wors that way
especailly since you did the lift
edit:
never mind, i thought you were thinking about durration
Old Apr 22, 2003 | 08:18 PM
Gripenfelter's Avatar
This is correct.
1.6 rockers affect lift not duration.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
