What are the downsides to no egr or air
Old May 10, 2008 | 02:20 AM
TBSPW's Avatar
Ive been wanting to take them off for sometime but j/w what problems might occur
Old May 10, 2008 | 06:21 AM
In NJ you will fail a "visual" inspection. Causes codes and the SES light if you don't have the diagnostics programmed out of the PCM. If they don't program them out correctly, you may get a "system not ready" flag for each, and too many of those will fail inspection. NOx emissions will go up, it they put it on the emissions dyno.
AIR helps the cats heat up faster on startup, running for about three minutes or so. No downside to removing it, other than increased emissions on cold start. Also no performance gains, other than the loss of a few #'s.
EGR helps cool combustion temp down mainly during low RPM cruise conditions, when you try and lug the engine in the wrong gear. Reduces oxides of nitrogen, and helps reduce the potential for detonation. Again, if you remove it, there is no perfromance gain. EGR only works below 3,500rpm at part throttle.
Old May 10, 2008 | 10:34 AM
MJ LEWIS's Avatar
i took my egr and air off there is really no difference except a little extra room under the hood just make sure the codes are deleted otherwise you will have a ses light
Old May 10, 2008 | 10:35 AM
ShownomercyZ28's Avatar
Where did you get checked for EGR/AIR in Jersey Fred?
Old May 10, 2008 | 11:41 AM
I don't take my car through NJ inspection any more, because its a "track" car now. But when the stroker was first built back in 2000, I was pushing 500 flywheel HP, with ALL the emissions equipment intact and functioning, including the cats, EGR, AIR, EVAP. It would pass the rolling/dyno emissions, and I knew a shop that would do the full, honest emissions, but overlook the fact that nothing in the engine was stock and the cats no longer matched the stock configuration. But back then, the MVC had the "mobile emissions unit" that would set up on the side of the road and do full dyno and visual emissions checks on cars pulled off the road at random. I was afraid someone would "notice" the mods on the engine, since the guys in the mobile unit had full manuals, and detailed knowledge of what they were looking for. The mobile inspection units seem to be limited to deisel truck checks now, so its probably not a problem like it used to be. I never actually had a problem with AIR/EGR because I just left it there.
Old May 10, 2008 | 11:47 AM
Ahh, cause when I took mine to get tested the geniuses thought it was FWD and proceeded to burn my E brake. But I need to find a local shop like you had done cause I am throwing longtubes on etc.
Old May 10, 2008 | 11:56 AM
The shops are not likely to "cheat". The MVC sends rigged cars into their shops, and if they don't find all the violations, they get a summons to a special court that deals with "emissions" violations only. The shop will lose their license, and the owner can be sent to jail for 6 months.
Its going to get worse, because in a couple years they are switching to CA emissions standards.
Old May 10, 2008 | 11:59 AM
Yea tell me about it, no more fun.
Old May 10, 2008 | 12:08 PM
rexcellent's Avatar
Damn, NJ just gets sh*tier by the day doesn't it. The emissions are no where near as strict down here, and somebody always knows somebody that can get you around it.
HectorM52
Jul 30, 2017 11:46 AM
k1996z28
Jan 21, 2015 07:22 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
