what does this head casting# fit 12551561 i need to know ASAP
Old Jan 25, 2003 | 02:35 PM
94 guy's Avatar
Question what does this head casting# fit 12551561 i need to know ASAP
guy says it's LT4 heads.
Old Jan 25, 2003 | 03:31 PM
Mtrhds94Z's Avatar
Aren't they the '561' 96-7 LT1 heads?
Old Jan 25, 2003 | 03:51 PM
NightTrain66's Avatar
It is a LT1 head. The LT4 has larger intake ports and 2.00/1.55 valves and the LT1 has 1.94/1.50 valves. If you have a LT1 intake compare it to the heads and you will see the dowel pins on the gasket are in a diff. location on the LT4 heads, they are closer to the outside of the head about 1 inch or so. Hope this helps. Someone may know the LT4 casting #'s but I do not.
NightTrain66
Old Jan 26, 2003 | 07:42 AM
arnie's Avatar
12555690 is the casting #
Old Jan 26, 2003 | 11:28 AM
Ai's Avatar
Ai
Many of the LT4 heads I've seen actually have "LT4" cast into the top of one of the port runners.
The guy is trying to sell you a 96+ LT1 head. Another easy way to tell the difference is that there is a rocker stud boss that protrudes into the port on LT4's, along with a ridge near the shortside between the two adjacent intake ports where the headbolt hole is, where all LT1 iterations have neither.
Old Jan 26, 2003 | 11:52 AM
arnie's Avatar
Oh, you talking 'bout those 'speed bumps', Phil?
Old Jan 26, 2003 | 11:56 AM
Ai's Avatar
Ai
No, I think restrictions hanging in the ports are what the LS1 guys love to claim are there to induce swirl! Swirl Swirl Swirl! Swirl my ***.
Chris Anderson
Jan 27, 2015 08:30 AM
Brake_L8
Jan 20, 2015 09:44 AM
ro2207
Dec 4, 2014 06:18 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
