what does this head casting# fit 12551561 i need to know ASAP
It is a LT1 head. The LT4 has larger intake ports and 2.00/1.55 valves and the LT1 has 1.94/1.50 valves. If you have a LT1 intake compare it to the heads and you will see the dowel pins on the gasket are in a diff. location on the LT4 heads, they are closer to the outside of the head about 1 inch or so. Hope this helps. Someone may know the LT4 casting #'s but I do not.
NightTrain66
NightTrain66
Many of the LT4 heads I've seen actually have "LT4" cast into the top of one of the port runners.
The guy is trying to sell you a 96+ LT1 head. Another easy way to tell the difference is that there is a rocker stud boss that protrudes into the port on LT4's, along with a ridge near the shortside between the two adjacent intake ports where the headbolt hole is, where all LT1 iterations have neither.
Chris Anderson
Jan 27, 2015 08:30 AM
Brake_L8
Jan 20, 2015 09:44 AM
ro2207
Dec 4, 2014 06:18 PM
