what do you think bout these head flow #s
Old Jan 22, 2005 | 12:57 AM
Seal's Avatar
valves 2.080/1.625
'stage 3 porting'
28 inch test pressure thest bore 4.030
100 - 72/60
200 - 140/117
300 - 190/144
400 - 228/158
500 - 252/178
600 - 256/187
700 - 248/186
my cam's lift is 560 btw...
whatcya think?
lt1 cast alum heads btw
Old Jan 22, 2005 | 03:05 AM
Jon A's Avatar
Re: what do you think bout these head flow #s
Originally Posted by Seal
valves 2.080/1.625
Old Jan 22, 2005 | 03:27 AM
SStrokerAce's Avatar
Originally Posted by Jon A
Agreed
Old Jan 22, 2005 | 03:45 AM
bunker's Avatar
Did they install new seats or just put these huge valves in? low lift idicated good flow cuz of big valve, after that it looks like its a restriction.
Old Jan 22, 2005 | 05:40 AM
sssalah's Avatar
Not very impressive especially with these large valves.
Old Jan 22, 2005 | 06:57 AM
GreenDemon's Avatar
Better than stock, but lacking when compared to Lloyd's. His usually flow 270/192 @ .600". Those numbers seem to drop off fairly early.
Old Jan 22, 2005 | 08:09 AM
Beyonce Knowles's Avatar
Here are the flor number for the LE stage 2 heads:
.2 136/102
.3 192/137
.4 238/164
.5 265/183
.6 271/188
I guess we're starting to use these as a baseline. For his price you can't beat them. Yours seems a little weak compared to these, especially for a "stage 3" job.
Old Jan 22, 2005 | 10:34 AM
Seal's Avatar
yeah, these are no LE heads, i would have loved to get those but these were a good price, so i went with these...
dunno why u guys are so suprised with the valve sizes... they are what they are.... could have gotten 2.100 if i wanted, but these were already built, so i just got'em
Old Jan 22, 2005 | 12:17 PM
transamtom's Avatar
I think they are suprised at the #'s with valves that size.
I posted my head #s yesterday and they are only about 10cfm lower than yours and my heads have 1.94 and 1.60 valves.
Old Jan 22, 2005 | 04:18 PM
Why we are so concerned over the valve sizes......
First a LT1 casting needs a new seat in the head for anything over a 2.00" valve. So "cheap" and a valve head diameter over 2.00" shouldn't go in the same sentence.
Second valve size relates to curtain area. Basicly the area around the valve at .XXX" lift. So a 2.00" valve @ .500" lift sees 1.570 Sq/in or area. You can only get so much thru a certain size hole. Depending on how close it is to the bore and if it's canted or not then plays a role in it too.
Bret
Old Jan 22, 2005 | 04:55 PM
AiSr's Avatar
While I'm playing on the old man's computer...
Bret is absolutely right on the 'cheap' comment. Before you run those heads I would highly recommend having a reputable shop check out what has been done - it may save you a great deal of trouble.
Good luck,
-Phil
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
InfernalVortex
Jan 17, 2015 09:35 AM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
