What do you think about this cam?
Old Feb 12, 2006 | 04:48 PM
modracr62's Avatar
I am building a 396 lt1 with le ported trickflows, le ported lt4 intake, 11.5 static compression going in a 3500 lb. camaro with a 3500 stall. I had comp help me with a cam. The specs are 248 256 @ .050 284 294 @ .020 with .672 lift with 1.6 rockers. It has a ls of 113+4. Valve timing on intake is 15 open 53 close and exhaust is 65 open 11 close all @ .050. Car is meant to be a bracket car but will see some street use. So what do you all think about the cam. I already have it but want to make sure it isnt a mistake before i put it in.
Tim
Old Feb 12, 2006 | 04:50 PM
JustNO's Avatar
Re: What do you think about this cam?
big cam for street use. Why 113 lsa ? will use nitrous?
Old Feb 12, 2006 | 05:14 PM
Chopstix's Avatar
solid or hydraulic roller?
Old Feb 12, 2006 | 05:16 PM
modracr62's Avatar
Comp recommended to go 113+4 for tuning. no nitrous. It is a solid roller
Old Feb 12, 2006 | 05:38 PM
1racerdude's Avatar
Did ya figure your DCR. Seems ya are leaving some on the table with 11.5 static.
A 108+4 would be better if the DCR checks out.
Ya have to use the ADVERTISED duration to figure the DCR.
Old Feb 12, 2006 | 05:50 PM
96m6lt1's Avatar
1racerdude hit the nail on the head! if you decide or think you may add n2o i would go to a 110 or 112 but pure motor 108
Old Feb 12, 2006 | 06:01 PM
96capricemgr's Avatar
I would say talk to Lloyd and Bret about the cam, you will be worlds ahead of talking to Comp.
Old Feb 12, 2006 | 06:02 PM
1racerdude's Avatar
Ya got THAT right.
Old Feb 12, 2006 | 08:36 PM
Really Comp is about the last place I would go for cam advise they have some good cams but their tech support is well poor at best.
Really I wish I had left it a little more open, AI, CM, or any of a number of other vendors here would also be better choices than calling Comp direct, these places also offer great deals on custom Comp cams. Vendors here are a lot more familiar with the LT1 than someone at Comp who deals with all makes and models and sees it as just a job. The 113 for tuning sake is proof positive of that. They guys you see here posting all the 400+rwhp even on stock bottoms are not running anything like that.
Old Feb 12, 2006 | 08:50 PM
Jameslt1TA's Avatar
If your putting this much into the motor already, i would highly recommend going with a custom cam made to work with your heads.
Old Feb 12, 2006 | 10:29 PM
94Z396_0621's Avatar
I done the LE Trick Flow heads for my Hydroulic Roller 398. And loyd and bret suggested what i need for a cam and had it made. Mines alot tighter than a 113 LSA. Yours should be a 110 or a 108. Talk to Loyd Elliott about it, he'll direct you in the right direction on your cam issue.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
