what do you think
Old May 8, 2008 | 12:59 PM
MJ LEWIS's Avatar
what do you think
i have a 96 lt1 camaro here are the mods i have done. i want to know what mods you think i shoud do. i also want to know what you think my car will run the 1/4 mile in as is. here are my current mods.
355 with forged internals
vortech blower 10psi
700r4 trans built with vigalante 3600 stall
comp cam 218/224 crane gold roller rockers
port and polished heads and intake
moser 12 bolt 4.10 gear eaton posi
bmr control arms and panhard bar
alston chasis torque arm adjustable and subframe connectors
hawk brakes
48# fuel injectors
full dyno tune
weld prostar xp wheels 15x5 front 15x10 rear
qa1 shocks front and rear front coilovers
hookers long tubes mufflex y pipe borla exhaust
cat and evap delete
bbk throttle body
Old May 8, 2008 | 01:02 PM
sl2racer's Avatar
first off why would you put a 700r4 in your car unless you are meaning a 4l60e...
and if you have some good dr's or slicks i would say somewhere in the 10's
Old May 8, 2008 | 01:11 PM
MJ LEWIS's Avatar
it has drag radials and the reason for the 700r4 is the car was orginally a six speed but it broke so i wanted a auto for drag racing
Old May 8, 2008 | 01:29 PM
blue 79 Z/28's Avatar
LCa relocation brackets if you dont have them, and maybe some suspension (shocks/springs). this a drag car or a street car?
Old May 8, 2008 | 01:30 PM
sl2racer's Avatar
well good luck with that trans
Old May 8, 2008 | 01:54 PM
MJ LEWIS's Avatar
i have lca brackets and this is a street and drag car i already have front and rear spring the front are qa1 300# and rear are new stocks
Old May 8, 2008 | 02:41 PM
tubular k member and tubular a arms. you got pretty much it all covered, only thing to do is go bigger on stuff. cam, displacement, better heads, more boost etc. id get a bigger then 3" catback for more power. you running the opti system still? maybe upgrade to an LTCC setup with the individual coils? LS1 front brakes are a good improvement also.
