what do you think?
Old Feb 18, 2008 | 08:04 PM
Black 97 SS's Avatar
what do you think?
LE1 heads, 2.00, 1.56 valves
Port matched intake from loyd
CC306 cam
30# injectors, 58mm holley, pacestter longtubes, MSD 6al, new wires, opti,
stock rebuilt rotating assembly, studded 2-bolt mains, clevite bearings, arp rod bolts, stock oil pump with white spring and 97' pickup tube.
4:10 gears
Motor is built, ready to be put in. Kinda late to ask but what does everyone think? ET, Horspower, Will it hold up? Live In Michigan so cant drive it or take it to track untill may.
1997 camaro SS #1039 M6
Old Feb 18, 2008 | 08:56 PM
white97T/A's Avatar
I think you will have 375 RWHP and be able to run in the range of 11.8-12.2E.T.'s.
Old Feb 19, 2008 | 11:06 AM
Think it will hold up? any others? thanks
Old Feb 19, 2008 | 01:08 PM
hosspwr94's Avatar
my guess will be around 325-350 at the wheels times all depend on driver, tires, transmission shifting and other related variables
Old Feb 19, 2008 | 04:47 PM
really lloyd was saying 390 to 400 at the wheels. I thought cam only was putting around 340-350 at the wheels. O ya forgot to mention full race weight. Thanks for the replys keep em coming.
Old Feb 19, 2008 | 04:49 PM
hosspwr94's Avatar
my bad I failed to see you were doing heads as well! then yeah I'd say Lloyd is probably right on!
