No start prob.
Old Feb 18, 2008 | 12:05 PM
Ca95Ztn's Avatar
No start prob.
Alright im havin a few problems. To start i have a 95 z28 with lt1 the engine is stock the only upgrades i have is a new transmission and cold air intake. so the car started boggin down whenever you put it under load and would backfire. once you turned it off it would not start again it will just turn over. hooked up scan tool and once i cleared the codes it started again. it did this twice. drove it home and once i turned it off for the third time it wouldnt start no matter what you did. so i was thinkin it had to be either the opti or the ecm. i borrowed a master tech(tech1) scan tool and it will not read any data, it will power up but does not read any data or codes and does not get a voltage signal. well i went ahead and replaced the opti, coil, plugs, wires, waterpump. all ignition parts are msd. once that was put in now when you turn it over it will just pop but wont start. so what do you think could it be computer or could it be somethin else...? any help would be great thanks.
Old Feb 18, 2008 | 02:17 PM
Ken95Z28's Avatar
Are you saying that you are not reading any data from the Tech 1 at all? I would think that you will still receive some type of data from the Tech 1 with just the key turned on. I know that my ScanMaster does that. If that's the case is there's somebody that you know that you can borrow their ECM?
Not to sure if you read the codes before you cleared them or not the first time, if so what were they?
Old Feb 18, 2008 | 02:31 PM
Ca95Ztn's Avatar
well at the first of the week it only gave a voltage readin and no data, on screen it will say no data available while koeo and thats while tryin to get into the datastream and tryin to check for codes and while doin a module check, and today its the same but now theres no voltage also, ive got a newer model s10 and i tried the scanner on it and it worked just wont do anything with the camaro. and no i dont know anyone.
Old Feb 19, 2008 | 05:32 PM
Ca95Ztn's Avatar
well got curious and tore the engine back down to check the distributor for a third time and sure enough i had it in wrong. runs great now and thank you for your help. but i still dont understand why a tech1 wont read anything so but again thank you.
Old Feb 19, 2008 | 06:08 PM
Ken95Z28's Avatar
Thumbs up
Good deal , I was going to suggest to check that, it's so easy to get these Opti's on the wrong way. Not to sure either on data output, but at least the car is up and running now.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
