What do you guys think of this?
Old May 22, 2004 | 06:52 AM
CoUnTryMuZiCZ28's Avatar
GolenEngine Service has a nice 383 motor for about 6299.. here are the specs::
Block: Thermally cleaned and Stainless-Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed. 4-bolt main caps.
Crank: Eagle Nodular-Iron
Rods: Eagle Forged 5140 Steel SIR, 6" Length, Floating Pin
Pistons: SRP Forged
Rings: Speed-Pro Plasma-Moly
Bearings: Clevite Main and Rod Bearings
Core Plugs: Brass Pioneer Core Plugs
Main Studs: ARP Main Studs
Lifters: Comp Cams Hydraulic Roller
Pushrods: Comp Cams High-Energy
Valve Springs: AFR Performance
Rocker Arms: Comp Cams Aluminum Full-Roller
Timing Set: Lunati Double Roller
Timing Cover: New Factory
Oil Delivery: Melling High Volume Pump, Pickup Tube and HD Drive
Oil Pan: New Factory 6-Quart
Gasket Set: Fel-Pro Performance
Head Bolts: ARP
Crank Hub: Factory to match Vehicle Year
Heads:
Type:
AFR 195cc LT4 CNC Ported Aluminum
... How does this sound? Anyone heard anything good about Golen? I have never heard of them untill a few days ago.. I will be using my own cam though.. it says it makes about 480HP/513TQ.. Whats your opinion on this motor? its a nodular crank too, not forged, i dont plan on modding it though, once i get this im done, no spray either..
Old May 22, 2004 | 10:07 AM
got_hp?'s Avatar
btw, what does this have to do with advanced tech?
for that price it should come with a forged crank, and more power, considering the heads. must be a mild camshaft.
as for their work, ive read some good reviews, but also i found threads like this
http://www.corral.net/forums/showthr...hreadid=135750
Old May 22, 2004 | 10:33 AM
What do oyou guys think of this?
I think its a good topic for "LT1 Tech"
You might want to find out more about the cam (specs) and the heads (who ported them, flow #'s).
They seem very proud of those "pioneer brass freeze plugs".... mentioned them twice.
Does it include the Opti? Is it the vented version?
Old May 22, 2004 | 11:58 AM
chy20k1's Avatar
after reading that thread i would never buy anything from them
Old May 22, 2004 | 03:14 PM
got_hp?'s Avatar
agreed.
stick with someone who has a proven reputation in the LT/LS world.
Bauer Racing Engines (website??)
http://www.horsepowerengineering.com
http://www.automotiveperformance.net
http://www.futralmotorsports.com
ive never heard a single complaint about any of those shops, just a lot of happy customers.
Old May 22, 2004 | 07:32 PM
chy20k1's Avatar
I'm going to have LAB do my machinework. theyve been around since the 60's and have done a motor for me before that i couldnt have been happier with. he also helps me out when i have questions. tought me alot. hes in lindenhurst NY.
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
