What do you clean the insides of Opt with?
Old Mar 30, 2007 | 03:48 PM
lr383's Avatar
Took apart Opt and it had some oil inside can you spray it with brake cleaner or electric contact cleaner. Just looking to clean optic part from oil.Thanks!
Old Mar 30, 2007 | 04:20 PM
Executioner2k5's Avatar
maybe some rubbing alcohol?? not sure tho
Old Mar 30, 2007 | 04:24 PM
qboneus's Avatar
Electronics Grade IPA shouldn't hurt\degrade anything and will leave no residue.
Tal
edit:Be sure it's Isoprophyl alcohol like 90+% for electronics
Old Mar 30, 2007 | 04:25 PM
wrd1972's Avatar
I have taking the opti completely apart, the only sensitive parts are the pulse wheel (dont bend it), the sensor and the bering. The sensor is only a pair of LED,s and can be cleaned with compressed air. I have even gone as far as separating the shaft and repacking the bearing, just mke dam sure you mark the orientation of the two parts for eassembly or timing will be off.
I personally do not think the opti is the almighty most hyper sensitve thing that many make it out to be. Once you have it apart it is easy to clean with a degreaser and a brush.
Old Mar 30, 2007 | 11:52 PM
lr383's Avatar
Thanks for the reply!
Anon
Jul 23, 2015 12:18 PM
dolfan324
Jul 17, 2015 10:34 PM
Latronaxe
Jul 17, 2015 11:55 AM
RUNMYTA
Jul 15, 2015 07:50 PM
