what to do while its apart?
Old Nov 14, 2003 | 10:04 PM
z28marine's Avatar
What should i do while while the engine is apart doing a cam and RR install? Any thing to replace, clean, or check?
Old Nov 14, 2003 | 10:21 PM
jasons93z's Avatar
get the heads worked
Old Nov 14, 2003 | 11:31 PM
Heatmaker's Avatar
Advanced Member
Get it Stroked
Old Nov 15, 2003 | 12:55 AM
Compstall's Avatar
Valve stem seals?
Old Nov 15, 2003 | 01:23 AM
94CamaroZ28's Avatar
Re: what to do while its apart?
If the heads are off.... might as well get ported and for sure a good valve job. Unless you are very low miles, valve guides may need work, seals for sure, just go through the heads.
Old Nov 15, 2003 | 01:33 AM
carlos64030's Avatar
Get a new timing set, or at the very least replace the chain.
