What to do....intake manifold bolt hole messed up :(
Old Feb 21, 2004 | 03:55 PM
xxsaint69x's Avatar
Angry What to do....intake manifold bolt hole messed up :(
Well one of the LAST bolts for the intake manifold striped!! What are my choices?? Space is lmited so there is no way i can drill a hole out for a heli coil? What to do!! help
Old Feb 21, 2004 | 04:46 PM
PatriotTA's Avatar
Are you talking about the hole in the block, that the intake bolts to? If I were you, I'd take a trip to Sears or whoever and buy a tap for that bolt. I believe its a 3/8"-16 x 1.38" bolt, according to Shoebox's website. Just chase the threads with a tap and then blow the chips out of the hole with compressed air. If that is still messed up, tap it out with the next size up and buy a new bolt.
Old Feb 21, 2004 | 06:09 PM
xxsaint69x's Avatar
yeah, the hole in the block....how wil the tap work if the hole is striped? Dont i have to make the hole bigger, tap it and put heli coil in?
Old Feb 21, 2004 | 06:35 PM
LilJayV10's Avatar
If the threads are there but messed up you can run a tap down it and clean it up, however if the threads are gone you will have to heli coil it. You can use a 90 degree drill, that would work better than a regular drill. Becareful and make sure you don't get any shavings in your engine.
Good luck
Old Feb 21, 2004 | 06:44 PM
JasonK94Z's Avatar
Do what patriot said first. If that doesn't fix it, go get a 90 degree drill to drill it out for a helicoil. They also make an air powered 90 degree drill also. Might be cheaper.
Old Feb 21, 2004 | 07:15 PM
xxsaint69x's Avatar
where can i get a 90 degree drill ? Is it the hole thing or just the drill bit...any ideas how much?
Marcin
Old Feb 21, 2004 | 07:58 PM
hsyr's Avatar
Is there any threads left at all? Try putting some JB Weld around the threads of the bolt then thread it in all the way down slowly then back out. Let it dry and cure completly and you should be good 2 go again. I've never done it myself but I know a couple people that have.
Old Feb 21, 2004 | 08:08 PM
xxsaint69x's Avatar
hmmm there is some threads left....any comments on the jbweld idea?
Marcin
Old Feb 21, 2004 | 08:19 PM
jakesnake123957's Avatar
bad threads
I think Permatex makes some thread repair product,it cost nine bucks,hope this works out for you>Jake
Old Feb 21, 2004 | 09:48 PM
93ZM6Tally's Avatar
Marcin,
What he said. I wouldn't go the JB Weld or Permatex route. A 90 degree drill would probably be expensive to buy, but should be able to rent one. Also a die grinder with a drill bit might work. Either should give you enough room to drill even up under the cowl.
Old Feb 22, 2004 | 08:55 AM
lillbush5555's Avatar
If u could drive ur car I woulkd tell you to bring it over and I will show you how to do it...But you cant SO I guess I will have to stop by and do it for you.
matt
Old Feb 22, 2004 | 06:06 PM
matt
That sounds like a pretty good deal.
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Mar 13, 2015 11:48 AM
Joes96z
Dec 13, 2014 07:48 PM
Jul 4, 2005 05:00 PM
