What do I set the rev limiter at?
Old Apr 14, 2004 | 01:05 PM
My Red 93Z-28's Avatar
Question What do I set the rev limiter at?
My mods are in my sig, I just want to know how high of rpms I can turn w/o hurting my new engine
Old Apr 14, 2004 | 01:38 PM
It's set at 6500 right now is that too much?
Old Apr 14, 2004 | 02:00 PM
Coolformula's Avatar
If you rebuilt the bottem end that should be "ok". I personally would set it at 6400 shift around 6300. Thats me though.
Old Apr 14, 2004 | 02:01 PM
I mic'd the crank and polished it, the connecting rods checked out ok. Any other opinions? Shoebox? Injuneer?
Old Apr 15, 2004 | 12:30 PM
bump
Old Apr 15, 2004 | 12:54 PM
You'll probably be ok as long as your rebuild tolerances were good and oil pressure is not an issue.
Old Apr 15, 2004 | 12:55 PM
GREGG 97Z's Avatar
I have mine set at 6500 with the hotcam kit and stock bottom end. I don't shift it that high, I shift around 6100-6200. To be safe I wouldnt take the stock bottom end beyond 6500, some people do but that's really pushing it to me.
Old Apr 15, 2004 | 01:10 PM
I have an HV oil pump and everything checked out so I guess I'll be ok, thanks for your help.
Is there something I can do to my stock rpm guage to make it show higher rpms? I really don't want to put a monster tach in.
Old Apr 15, 2004 | 01:20 PM
GREGG 97Z's Avatar
What do you mean? I'm not sure about 93's but my stock gauge goes to 7K. The stock gauge isnt very accurate though. I use a Harlan shift light, it's pretty inexpensive and very accurate, it can be set to come on in 100rpm increments. It mounts in the little vent hole at the bottom of the A pillar, its hardly noticable when its not lit up.
www.harlan-engineering.com
Old Apr 15, 2004 | 01:43 PM
i know it goes to 7k, but it's in red and like you said, "not very accurate" plus my a-piller doesn't have the little vent hole.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
