what do i need to run the cc306
Old Mar 5, 2006 | 04:59 PM
redington's Avatar
ok guys what parts do i need to order to run the cc306 what rrs and all that stuff. what size rrs would i need? springs? push rods?... what do i need? Please let me know thanks
-mike
Old Mar 5, 2006 | 05:03 PM
LUDA0840's Avatar
Re: what do i need to run the cc306
Well I got the chromoly pushrods from comp cams, the 918 beehive springs from comp cams, 1.6 rr's from compcams, retainers and valve locks from comp cams, you'll need a new timing chain and the gaskets. I think thats all if im not mistaken. also its good to have ur heads ported for this cam. Dont go cheap on your valvetrain!!
Old Mar 5, 2006 | 05:05 PM
TransAm396's Avatar
springs... behives, pushrods- comp Hi-techs(7.2") 1.6 RR...promags... 7/16th studs..and the studs...front timing gasket set, new timing chain..do a search its been asked a MILLLION times..
Old Mar 5, 2006 | 05:40 PM
redington's Avatar
about how much in parts are we looking at here... im going to go with some aftermarket heads down the road i just want something i can do in steps. because if i did the aftermarket heads and cam all at once it would kill me.
-mike
Old Mar 5, 2006 | 06:15 PM
doug1105's Avatar
Maybe the admin guys can do a sticky or a something that corrals all the popular cam/valvetrain combos, so the search part isn't so time consuming.
Old Mar 5, 2006 | 07:00 PM
redington's Avatar
that would be good a cam sticky
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
