what do i need to run the cc306
ok guys what parts do i need to order to run the cc306 what rrs and all that stuff. what size rrs would i need? springs? push rods?... what do i need? Please let me know thanks
-mike
-mike
Re: what do i need to run the cc306
Well I got the chromoly pushrods from comp cams, the 918 beehive springs from comp cams, 1.6 rr's from compcams, retainers and valve locks from comp cams, you'll need a new timing chain and the gaskets. I think thats all if im not mistaken
. also its good to have ur heads ported for this cam. Dont go cheap on your valvetrain!!
springs... behives, pushrods- comp Hi-techs(7.2") 1.6 RR...promags... 7/16th studs..and the studs...front timing gasket set, new timing chain..do a search its been asked a MILLLION times..
about how much in parts are we looking at here... im going to go with some aftermarket heads down the road i just want something i can do in steps. because if i did the aftermarket heads and cam all at once it would kill me.
-mike
-mike
