what do i need to get into the 12's
i wanna know what do i need to get into high 12's with out doing major engine work (like heads and cam) my mods are corsa cat-back, mac midlengths, off road y pipe, nittos, cai, descreened maf, hpp,airfoil, fresh tuneup with msd wires, and 3.73's.
You should be close right now. At least deep into the 13s. Throw on some 1.6 rr's too. Oh and try a cut out as well. Dont know what kind of gain you'll get over the Corsa if any but you'll see a gain regardless.
Put a converter in should knock off at least 3-4tenths of second,put on electric water pump and set of pullies,Or you can lose the mid lentgh headers and get set of long tubes if your not worried about emmisions.These mods will put you close to mid twleves.
Ya you should be VERY close to 12's. I'd say look at some 1.6 RR's and make sure you in in good tune. Also remember that aproximately ever 100lbs you can drop off your car will be worth .1 sec in the 1/4. And also look at what your 60' times. Do you have any suspension mods yet? TQ arm, lower control arms, etc?????
Josh
Josh
