What do I need to change for 306 cam? ???????
Re: What do I need to change for 306 cam? ???????
Yeah springs and a tune are manditory and you will be amazed at what they gain you.
What other mods are done to the car? Think about putting a sig together to help us better help you.
I went the route of a cam before headers,stall, gears and even with a MUCH milder cam it didn't work too well till I began to get those other parts on the car then it REALLY woke up.
Must have proper Valvesprings other items should be from stock: CAI, headers, catback, roller rockers, tune, and head work if you can afford it. I got #'s in sig with stock heads though.
You need new springs, retainers, seats, valve seals, roller rockers (the stockers suck, and will deflect at higher lifts), new pushrods (hardened) if you're using guideplates (non self aligning rockers), stock pushrods with self-aligning rockers, new timing chain, new gaskets, probably new opti and waterpump while it's all apart, you need a tune (mailorder at least). You'll need some other misc. stuff depending on what year your car is. Do some searching. http://shbox.com/ci/cam_install.html
I'd recommend:
Comp 918 springs
10* steel hardware (titanium if money is no object. Also do a search for 918)
Cloyes Double roller timing chain (requires 95+ opti, electric wp, clearancing)
Intake, timing cover, waterpump gaskets
1.6 Roller rockers
Tools
Look at the pictures in my thread a couple up from here
Comp 918 springs
1.6 Roller rockers
Tools
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
