What do I need for a
Old Jul 7, 2003 | 08:40 PM
DamianLT1's Avatar
Cam swap & intake manifold fix as far as gasket go? I'm trying to a the best bang for my buck since funds are very low.
Old Jul 8, 2003 | 05:52 AM
DamianLT1's Avatar
anyone?
Old Jul 8, 2003 | 08:43 AM
quicksilver97ta's Avatar
You would need everything in a timing chain gasket kit and a pair of intake gaskets and a tube of silicone. Most autoparts stores will carry a t.c. gasket kit or at least be able to itemize this for you. Off the top of my head I can think of the water pump gaskets, timing cover, opti seal, w.p. drive seal and crank seal. With the intake gaskets you should get an egr pipe gasket and maybe an egr gasket and injector o-rings. Hope that helps.
Old Jul 8, 2003 | 10:31 AM
DamianLT1's Avatar
