What do I have?? Internal pics (LONG)
Re: What do I have?? Internal pics (LONG)
I took a piston out and it measure's 3" 15/16 across. The bearings were clevite 77's. They looked wore pretty bad to me. I'll post some more pics when I get them up loaded. I apreciate all y'alls help.
Originally Posted by NVetro
The pictures appear to be from the front of the motor, Can you get us some of the rear of the motor so we can see if the rear of the block has been notched to fit the 3.75" stroke crank that a 383 requires. That should help us figure out what it is. By front of the motor i mean an aerial view of the rear of the block, kinda like the pics u took, but onthe back not the front.
If the back part of the pan rails have to be clearenced, so do the front.
Yea true, didn't think about that. I just looked at the picture again, doesn't it look like it was notched? Looks like some metal was moved to clear the counterweight. Check it out...unless thats how the stock block is cast, i forget what mine looked like.
What were your throw measurements? Inquiring minds want to know.
I just tore down a bone stock 96 lt1 today. The pistons have the same 19/12 number on top,the rods are stock pm rods.Your crank looks much more machined on the counterweights than any of the cast lt1 cranks i have,it may have been replaced with a different crank,but i'm sure the pistons & rods are stock.
stockssn2o
May 25, 2015 08:54 AM
Henson071
May 4, 2015 12:23 PM
canbaufo
Feb 24, 2015 10:27 AM
