What do I have to do to a Holley TB to make it work correctly?
Old Sep 14, 2006 | 02:35 PM
2QUIK6's Avatar
Ok, I guees I'm stuck with purchasing a 58mm Holley TB, seems to be the only one thats has the IAC passage sealed from the main plenum to try to fix my idle issues.
I've read several posts about them sticking and other issues, but there seems to be ways to correct some of that.
If you have a Holley, what if anything did you do to resolve any issues you may have been having?
Sure sux that no one can make an aftermarket TB that has the same ports/holes/etc as the stocker...
Old Sep 14, 2006 | 02:47 PM
SC/TA's Avatar
Re: What do I have to do to a Holley TB to make it work correctly?
I have had mine for about 6 months. So far I have had no problems. I did enlarge the iac opening between the throttle blades (on the front side). I did this to lower the IAC count some. Like I said so far i am very happy with it.
Old Sep 14, 2006 | 02:59 PM
The Engineer's Avatar
Send me a PM with your personal e-mail address and I'll send you some pictures of a fixture I designed and built to machine-out the intake venturas to 58mm. It works great and I've done several. I see you're in Ft Worth, I'm in the Oklahoma city area, not too far away.
The Holley 58mm is a great TB for an LT, possibly the best!
Old Sep 14, 2006 | 05:25 PM
2QUIK6's Avatar
You mean adding the venturi hole like in this link?
http://members.***.net/chipsbyal/page/idle/index.html
I anticipate doing this minimally to any aftermarket TB. I know the Holley seals up and does not allow IAC air to the main plenum which is good for idle quality so I will not have to make a "plug" to seal that off as shown in the link above.
Old Sep 14, 2006 | 11:24 PM
SC/TA's Avatar
I didnt add anything, I just enlarged the hole with a dremel. Its kind of a triangle shaped hole on the front side of the tb( not the intake manifold side). You may not have to do it. just check your IAC count. You can also lower the iac count by opening the throttle blades a little, by turning the throttle stop screw. I liked the idea of useing the iac to regulate how much air your getting. Thats just my opinion, it may not matter which way you do it.
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
Eric H
Aug 10, 2002 06:39 AM
Highlander
Aug 9, 2002 02:30 AM
