what do i do now??
Old Mar 31, 2007 | 03:39 PM
jlmeraz's Avatar
what do i do now??
hello to all,
I noticed today that my 97 z28 is running without the temp sensor... i opened the hood and the green wire trhat attaches to the sensor head has been "burned" off.. what do i do?? my car was never running hot but im sure with my luck itll over heat and ill never know it..
another ?
out of curiousity will my "check gauges" light come on if my car over heats, even though the gauge isnt actually working??
thanks in advance guys?
Old Apr 1, 2007 | 05:38 PM
Which coolant temp sensor are you talking about - the single wire sensor in the driver's side head (gauge only) or the two-wire sensor in the water pump housing (PCM feed)?
If its the one for the gauge, splice the wire. If the connector is damaged, get a new "pigtail".... a new connector with a length of wire attached to it. The "Check Gauges" light is tied into the coolant gauge, not the PCM.
