What to do with a HIGH MILEAGE engine
Old Oct 10, 2008 | 10:21 AM
  #31
MTBSully's Avatar
Originally Posted by JackB03
Rather do that or should I just rebuild the one I got?
-Jack
if your going 383, work with what you have. Im sure the block is in fine shape. Get a nice bottom end in there and you will be all set
Old Oct 10, 2008 | 11:48 AM
  #32
6SpdLT1Z's Avatar
If your shooting for 450+hp I'd opt for a new bottom end. Whether it be rebuilding what you have, or buying a new long/shortblock is up to you and your budget.
Old Oct 10, 2008 | 06:18 PM
  #33
Scotts94z28's Avatar
I bought my 94 new, so I know how it has been maintained, and how it was treated. I drove it hard for 14 years, and maintained it very well. It was my daily driver until last december when I bought a truck, still drive it on the weekends though. I currently have 265,000 miles on it, and only had the intake off once to fix the oil leak. No doubt its worn out, loss of power, smokes, ect, needs a rebuild which is on the to do list. However it didnt start using oil or smoking until round 240,000.
Old Oct 10, 2008 | 07:22 PM
  #34
JackB03's Avatar
I guess Ill just get new pistons, rods, change all the bearings and new oil pump...it that all of the bottom end or am I leaving out something?
Old Oct 10, 2008 | 09:31 PM
  #35
andysc's Avatar
196k on the clock and still runing fine. I am doing boltons, may do heads, but don't want to do a cam. so you have another almost 100k left if you take care of it.
Old Oct 10, 2008 | 09:39 PM
  #36
MTBSully's Avatar
thats it. change the cam bearings while your in there too. Piston rings as well. The stock crank is pretty stout but i dont know if you would want to replace that or not.
Old Oct 10, 2008 | 09:55 PM
  #37
McLovin's Avatar
Originally Posted by 6SpdLT1Z
104k != high mileage.
Mine's got 151k and I'm just now camming it and retiring it from DD (Will only be DD from May-August)
Mine has 182,xxx. Cammed it once at 165,xxx then tossed a bigger one in at 179,xxx.
Old Oct 11, 2008 | 10:14 AM
  #38
LaredoZ28's Avatar
High mileage engine. I say tear it down and rebuild it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jason Short
Jan 19, 2015 06:34 PM
Dec 1, 2014 08:08 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
