what is different between LT1 cam & 87 up cam
Old Apr 10, 2003 | 04:22 PM
sweet94Z's Avatar
What is the difference?Just the dowel pin length? Thanks.
Old Apr 10, 2003 | 05:05 PM
Mindgame's Avatar
The core is a bit different because the Optispark is driven off the cam. Other than that, not much else is different other than the dowel pin lengths.
-Mindgame
Old Apr 10, 2003 | 07:38 PM
sweet94Z's Avatar
What exactly is different about the core? Can you run one in an lt1 safely?I was thinking that on my car the top timing gear actually drove th opti. Thanks again.
Old Apr 10, 2003 | 08:36 PM
Mindgame's Avatar
The difference is in the center hole on the face of the cam. The hole size depends on the distributor shaft used (early or later). You can read and see the differences at this site, http://www.automotiverebuilder.com/ar/ar99928.htm
Still have the stepped snout like all 88-up cams, just the difference in the "drive-hole".
HTH.
-Mindgame
Old Apr 11, 2003 | 08:57 PM
sweet94Z's Avatar
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
Kyle@CSS
Sep 14, 2002 04:06 PM
Brendans Z
Sep 11, 2002 05:29 PM
