what is different between LT1 cam & 87 up cam
The difference is in the center hole on the face of the cam. The hole size depends on the distributor shaft used (early or later). You can read and see the differences at this site, http://www.automotiverebuilder.com/ar/ar99928.htm
Still have the stepped snout like all 88-up cams, just the difference in the "drive-hole".
HTH.
-Mindgame
HTH.
-Mindgame
oldschool
Feb 9, 2016 09:21 PM
