What did i break? pics inside
Old Jul 8, 2005 | 10:29 PM
JJJ93z's Avatar
while pulling off my driver side manifold, i kinda caught this silverish thing above the oil filter, not sure what it is or how to fix it
http://community.webshots.com/photo/...90056193meKykB
http://community.webshots.com/photo/...90056039fHSMYT
up above is the bung that it was on
Old Jul 8, 2005 | 10:37 PM
Re: What did i break? pics inside
Oil pressure sensor.
Old Jul 8, 2005 | 10:40 PM
SUTTERERMAN85's Avatar
that would be your oil pressure sending unit. you will need to get the rest of the old one out of the block and put a new one on before you start. other wise you will not have oil pressure and it will leak or **** all over the gound.
Old Jul 8, 2005 | 11:14 PM
JJJ93z's Avatar
thats what i kinda figured it was, shoebox if i didnt get a response from this post my next step was to check out your site, thanks for the quick response guys. also i should probably drain the oil before i change it and its only held onto by that nut that in the block right? should i change that after i put my LTs in as well? thanks
Old Jul 8, 2005 | 11:17 PM
There won't be any oil draining out when you remove the sensor. Just a drip or two. It is a pressure passage. Most of the oil will already be drained back to the pan.
Old Jul 8, 2005 | 11:39 PM
JJJ93z's Avatar
is this still true even if the car is raised in the front? also this is the correct part number right? since its a 93 its the first design.
24575127 $25.72
Old Jul 9, 2005 | 08:19 AM
24575127 $25.72
Yes and yes.
NewsBot
May 15, 2015 10:10 AM
cmyname1
Feb 19, 2015 08:38 PM
rjc1629
Jan 27, 2015 10:46 AM
omarECD
Aug 19, 2002 07:28 AM
