What cylinder heads and valve train
Ok well somthing with my valve train is messed up. So its just an excuse to redue the whole top end. But my question is if I were to put some new main and rod bearings in the motor. What cylinder heads would you guys go with along with what cam and other valve train components. Stock pistons, rods, and crank in there also.
Re: What cylinder heads and valve train
well first off
what makes you think your valve train is messed up???
id say your first step would be to se what went /is going wrong
but any way as far as heads and cam i think a really safe bet would be to go with lloyd elliot and one of his heads and cam combos
lloyd does great work with the heads and Bret who does the cams for him does a fenominal job as well
id say either LE1 or LE2 or something in between would be right up your alley
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
