What could cause this
Old May 28, 2012 | 09:49 PM
77 Formula's Avatar
The low oil,asr off,check gages,and abs inop lights are all on when running. I have checked the oil and the asr switch. What could cause these to stay on
Old May 28, 2012 | 10:35 PM
Re: What could cause this
Low voltage is often the cause.
Old May 29, 2012 | 10:39 AM
77 Formula's Avatar
OK Thanks I'll check my voltage
Old Jun 20, 2012 | 09:51 PM
77 Formula's Avatar
I checked my voltage it's good now what do I need to check. I have a new problem too when I start my car the windows or radio don't come on sometimes I can turn it off and start it and they start working what all could cause this?
Old Jun 20, 2012 | 10:52 PM
What are your voltage readings? There is not any car info. What are you working on?
Old Jun 21, 2012 | 06:10 AM
77 Formula's Avatar
I am working on a 97 camaro with LT-1.My voltage reading is 14.0 at idle and 13.8 under a load at idle.
Old Jun 21, 2012 | 08:13 AM
The windows and radio issue could be from the RAP function in the BCM. Maybe a connection at the BCM or it might be flaking out.
Old Jun 23, 2012 | 08:56 PM
HardcoreRM125's Avatar
Im'a say Body Controll Module ... everytiong at once is impossible. Def electronic failure somewhere.
