What color is the Fuel Pump hot wire?
I need to know, its on a 95 Camaro and we just switched it to Carbed SBC and I want to use that wire since I still have the computer hooked up so the lights and what not are working.
Re: What color is the Fuel Pump hot wire?
It depends on what wire/where you want to use.
The wire from the f/p relay to the pump is grey. The wire from the PCM to the relay is dark green/white.
Skull Leader
Aug 10, 2002 11:01 AM
