What coil are you guys using?
You probably won't see any gains from an aftermarket coil on a relatively stock engine other than a smoother idle-if that. I put on an MSD coil and it make no difference whatsoever, but if I was running N2O or a supercharger, then yes I would run an aftermarket coil with an ignition control box.
I got increased fuel mileage..
17 mpg - noticed there was something wrong..
19.5 mpg - replaced the locking gas cap with an original GM one..got back the power and gas mileage
21 mpg - replaced the stock coil with an MSD blaster coil
20.2 mpg - changed to 3.42's
23.6 mpg - cleaned out my air filter that had been down there for 9 months..bloody muddy if you asked me..
This is with the mods below...
Did changing the gas cap really make a difference? I have a locking one as well and maybe I should get rid of it.
Sergio
Jan 27, 2016 04:27 PM
