What is code 50?
Old Jul 27, 2004 | 01:13 PM
95 Mystic TA's Avatar
What is code 50?
My Scanmaster is displaying code 50. I looked it up on the list of codes on Fred's Scanmaster write-up but didn't see it. Anyone know?
Old Jul 27, 2004 | 01:21 PM
944v8inDFW's Avatar
Re: What is code 50?
50 System voltage low You thumpin your stero while checkin? Or your battery / alt. may be getting weak. Did it trip a light or shows when you scan?
Old Jul 27, 2004 | 02:02 PM
Thanks for the reply. I slung my belt off and it drained the battery significantly. When I got the belt back on, the car cranked up fine and the battery voltage was around 13 on the Scanmaster.
I did check it while the battery was low. Should it still flash 50?
Old Jul 27, 2004 | 02:24 PM
Once you have your power problem solved, reset the computer. The DTC should then be gone.
Old Jul 27, 2004 | 03:24 PM
That crossed my mind right before I re-checked this thread. Thanks
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
